SER-CAT banner
User Program
ANL_aerial_photo
APS User Agreement
In order to work at APS, your institution must first have a User Agreement in place with APS.
APS_Portal
APS User Registration
Anyone who does work at APS, even from a remote institution, must first register as an APS User.
Depending upon circumstances, this can take time, so best to start early!
More
Calendar_2020_04
Beamtime Requests
SER-CAT schedules beamtime for an entire run, and releases the schedule a few weeks before the run begins.
Details for requesting beamtime, and finding out assignments, given below.
More
ESAF_form
Experimental Safety Approval Forms (ESAFs)
A fully-approved ESAF is required before you may begin working on either of the beamlines. Submit early.
Institutional run-wide ESAFs are now required for all SER-CAT Users.
More
OSHA
Hazardous Materials
Hazardous Materials include:
  • solid propane popsicles or liquid propane,
  • shipping a liquid nitrogen dewar filled with liquid nitrogen,
  • heavy atom soaks.
More
steel_pin
Pins, Bases and Pucks
Particular pin bases and pin lengths are required for working at SER-CAT. Suggested vendors and part numbers are included in the "More" section, below.
In addition, we suggest a few tips and pointers which can make life easier for everyone.
More
Shipping_Container
Shipping Dewars
Use correct address, and present-day staff member's name, when shipping dewar. Both FedEx and UPS deliver.
Label container clearly as designated for: present-day staff member, SER-CAT, sector 22, building 436B.
More
ESH223
Required Training
If you are using the beamlines remotely, then only ESH223 will be required; training needs to be updated annually.
If you are going to be on-site, then a few more courses will apply.
More
Zhongmin
Sector Orientation
If you are conducting your experiment on-site, interactive training is required with your host, including:
  • use of the beamlines
  • searching/securing D-hutch
  • tour of facilities.
More
Privacy and Security Notice
